Adding To Your Cart...
Diagnostic Scanners - Engine for BMW F32 440i Coupe (2017-2020) 3.0L
WAS 179.99 on 09/16/2025
SALE shows the updated price of an item after a reduction from the previous retail price.
The WAS strikethrough price is the price offered for the item on Pelicanparts.com on 09/16/2025.
SALE:
$134.99
(25% OFF)
May Qualify for
Free Shipping!
- 440i Coupe (2017-19)
Cars with 20-pin round connector should also use adapter cable PEL-014020SCH02A.
Schwaben scan tools by Foxwell are recommended for OBD faults, OE-level diagnostics, other specialized needs, troubleshooting and more for DIYers. These code readers will be your best friend to help you diagnose your Check Engine Light, troubleshoot OBDII/EOBD problems and access the most commonly required service features, all in a high quality, cost-effective manner!
Developed specifically for BMW/MINI vehicles, use your car's OBD diagnostic port (or, for BMW, using the BMW 20-pin adapter part number 014020SCH01A), to pull codes (part number 014020SCH01A), live data and also performs some advanced functions such as actuation, adaptation and programming (check full list of available functions in link below).
In order to check specific vehicle coverage and functionality, visit
https://www.foxwelltech.us/support-fun-list.html
Enter your device (this device can be found under NT510 Elite on Foxwell's site), your vehicle, and what code you are querying
Features Include*:
  • BMW/MINI updated firmware is now compatible with the BMW/MINI F series.
  • Loads faster and finds troubles more accurately and quickly.
  • New color screen for easier reading.
  • Gets access to trouble codes and freeze data of powertrain, chassis and body systems
  • Auto Scan function scans vehicle systems in just seconds
  • Shows live vehicle sensors data in text and graph formats
  • Merges interactive live sensor graphs
  • Records and playbacks data-logs to catch intermittent failures
  • Retrieves ECU information
  • Runs component/system bi-directional tests
  • Supports advanced functions such as adaptations and control module coding
  • Supports the most commonly required service features like steering angle sensor (SAS) calibration, DPF regeneration, ABS bleeding, BCM/SIR setup, etc.
  • Upgradable to cover more car makes at unbeatable value
  • Multi-language menus and codes for an international marketplace
  • Extremely easy to use with clearly arranged keypad, menu-driven operation and shortcuts
  • Ergonomic design and ruggedly built for both shop and road tests
  • Can reset most batteries but cannot change battery load setting or convert from AMG to Lead Acid at this time or vice versa. Possible in the future with software updates.
Supported Protocols: J1859-41.6, J1850-10.4, ISO9141, KWP2000 (ISO 14230), and CAN (Control Area Network ISO 11898)
For a full list of available functions for BMW, Click Here!
* Certain functions may be limited from the vehicle manufacturer due to the requirement of a special factory access code.
WAS 99.99 on 09/16/2025
SALE:
$74.99
(25% OFF)
May Qualify for
Free Shipping!
- 440i Coupe (2017-20)
This code scanner tool works with all OBDII/EOBD cars and hybrids worldwide.
Don't let your check engine light be a mystery any longer! With the OBDII/EOBD Code Reader diagnosing error codes has never been easier.
With its 2.8" TFT color screen, simply plug the code reader into your OBD-II Port for a clear readout of your vehicle's diagnostics.
https://www.foxwelltech.us/support-fun-list.html -
Features Include -
  • Reading/Erasing DTC and I/M hot keys make it easy to use and provide quick access to emissions readiness status, DTC information and erase function
  • RED-Yellow-Green LED's with built in speaker indicate emissions monitor status at a glance and can help catch intermittent problems or confirm repairs during drive cycle
  • Automatic VIN acquisition and decoding. Making it much easier to read manufacturer specific codes and enhanced mode 6
  • Read and clear engine system faults
  • Shows live sensors data in text and graph format
  • Reads freeze frame data
  • Multilingual - English, French, German, Spanish, Polish and more
  • Reads stored, Pending and Permanent codes
  • Compatible with 1996+ OBDII
  • Also has a print data function
WAS 479.99 on 09/16/2025
SALE:
$359.99
(25% OFF)
May Qualify for
Free Shipping!
Wireless connection, bi-directional control, and better hand-feel set the i70BT apart from the i70 module while maintaining the affordable cost for enthusiasts.
The Foxwell i70BT is your solution for a tablet diagnostic scanner that will elevate your level of diagnostics without breaking the bank. This unit is one step above the standard i70, and we'll explain why below. This heavy-duty tablet can withstand any work you put it through and will find its place in any garage or shop. The i70 is unlocked with almost any manufacturer you will interact with and is pre-loaded to be compatible up to years 2019/2020 - plus 3 years of free updates to stay relevant for years to come. With dozens of features, 35 additional maintenance functions, and backed by a LIFETIME REPLACEMENT program, this scan tool will get the job done right, every time.
i70BT vs i70:
  • NEW - Fox Link I: i70BT can wireless connect to your vehicle AND supports CAN/FD protocol
  • NEW - Bi-directional control on i70BT
  • i70BT is more up-to date off the bat (vehicles 2020/2021, and still including 3 years of free software updates to stay up-to-date)
  • Hardware -
    • Display: 7" color LCD Screen that is daylight-readable
    • Memory - 1 GB DDR3L
    • Storage - 32 GB SSD
    • Connection - Wireless VCI
    • Battery - 4000 mAh
    Standard Features -
    • NEW - Wireless Connection with Foxlink I
    • NEW - Supports CAN/FD protocol.
    • NEW - Bi-directional control.
    • Loaded with the latest models on most cars 2020/2021 and with 3 years of free software updates.
    • Compatible with latest models, including cars, SUVs, Minivans, and light duty trucks.
    • Get access to power-train, chassis, and body systems.
    • Identifies vehicle quickly and easily with automatic VIN reading.
    • Auto Scan function scans vehicle in just a few seconds.
    • Reads and clears diagnostic trouble codes.
    • Supports the most commonly required service features like brake deactivation, service resets and transmission adaptations.
    • Supports ABS bleeding and IMMO functionalities
    • Runs on latest Android operating system.
    • Screen is usable with gloves.
    Data Display -
    • Views live vehicle sensors data in a text, graph and gauge formats and allows you to focus on any suspicious data.
    • Merges multiple interactive sensor graphs, providing you with the most comprehensive and functional look at live data.
    • Live data self-learning and alarms when data is over range.
    • Records and plays back live data logs to catch intermittent faults.
    • For coding features, check out the i70Pro (ES#3698691)!
    Extra Features -
    • One touch update via Wi-Fi lets you always have the latest bug fixes, new vehicles, and functionality at your fingertips.
    • Unique debug logging feature allows for quicker and more accurate fixes for diagnostic troubles and bugs.
    • Instant support available from Foxwell's technical team by TeamViewer remote control
    Kit Includes -
    • i70BT Main Unit
    • VCI Dongle
    • USB-C Cable
    • USB Charging Adapter
    • Quick Start Guide
    • Warranty Card
    • User Manual
  • $799.90
    May Qualify for Free Shipping!
    WAS 339.99 on 09/16/2025
    SALE:
    $254.99
    (25% OFF)
    May Qualify for
    Free Shipping!
    Vehicles with 20 pin under hood connector will require ES2992111 for use.
    The Foxwell i53BT Tablet Scanner is a versatile tool that provides comprehensive OE-level diagnostics for a variety of car brands while offering essential service and coding features. With regular hardware and software updates, this tool empowers both technical professionals and automotive enthusiasts to tackle automotive issues with heightened precision and efficiency. It's the ideal choice for enthusiasts seeking next-level diagnostic capabilities without the typically steep costs associated with diagnostic tools.
    Works on all OBDII/EOBD compliant vehicles
    Features -
    • Includes BMW and MINI software
    • Works with latest 2021/2022 models and all models 1987 to present (older models may require an adapter to fit OBDII module)
    • Fast Android operating system and interface that finds troubles more accurately and quickly
    • 5.5 inch LCD Touchscreen that responds to glove use
    • Bluetooth wireless VCI vehicle interface plug for a cordless OBD2 experience
    • Supports DoIP and CAN FD protocol
    • One Touch Update via WIFI
    • One Touch Complaint allows for quicker and more accurate fixes
    • Access to get remote control support by TeamViewer at the scanner home screen
    • Data Logging service allows collection of communication data between the scanner and the vehicle under test to help with troubleshooting of diagnostic failures faster and more convenient
    • Print diagnostic reports via WIFI
    • Free updates for life (no subscription required)
    • Easily add more vehicles to support at additional fee
    • 32GB SSD Storage Space
    • 1GB RAM
    More Features -
    • Supports coding KOMBI, AMP, DME, plus many more.
    • Supports VANOS realignment for intake/exhaust and displays tolerances during testing.
    WAS 289.99 on 09/16/2025
    SALE:
    $217.49
    (25% OFF)
    May Qualify for
    Free Shipping!
    The Foxwell TS5000 Tablet TPMS Service Tool serves as your first or second step into TPMS diagnostics. It is a mid-level TPMS tool that provides the ability to activate OEM/Universal TPMS sensors, retrieve TPMS sensor data (sensor ID, tire pressure, temperature, battery condition and OE part number), relearn 98% sensor IDs, program FOXWELL T10-sensor to replace bad sensors and test Remote Keyless Entry Key Fobs. With regular hardware and software updates, this tool empowers both technical professionals and automotive enthusiasts to tackle automotive issues with heightened precision and efficiency. It's the ideal choice for enthusiasts seeking next-level TPMS diagnostic capabilities without the typically steep costs associated with TPMS tools.
    Standout Features (How does it standout from previous models, i.e. the T1000/T2000?) -
    • Will allow you to connect to all sensors at once and view all of their data at the same time
    • Can now program sensors by copying through OBD (eliminates need for relearn, see "Programming" in description for details)
    • Wireless connection to OBD2 port
    • Wireless updates (One Touch Update)
    • Larger screen (5.5-inch screen, T2000 is 2.8-inch)
    • Updated, larger hardware (32 GB RAM, 5V battery, now offers camera for VIN-reading)
    • CAN FD support
    • Print TPMS sensor data on PC
    More Features -
    • Activate 98% OEM/Universal TPMS sensors
    • Programs FOXWELL T10 Sensors in 4 Different Ways: Copy by OBD, Copy by Activation, Copy Manually, and Auto Create Sensors
    • 3 TPMS Relearning Methods: OBD Relearn, Automatic Relearn, and Stationary Relearn
    • Fast Reading Sensor Data: Include sensor ID, tire pressure, temperature, battery, frequency, etc.
    • Key Fob Testing Tool: Precisely test 315MHz and 433MHz key fobs to ensure whether it is perfectly running
    • Read TPMS Live Data
    • Basic Code Reading capabilities using OBDII
    • Solid and Rugged Construction: Well-constructed with materials designed to handle harsh work environments
    • Intuitive and Easy Instructions: Easy to navigate and operate with clear instructions and detailed user manual
    • Free Software Updates for Life
    • LIFETIME REPLACEMENT program
    Programming -
    With this TPMS programming tool, you can program FOXWELL T10 TPMS sensors to meet the specifications of a particular vehicle before new sensor installation and relearn. 4 different sensor programming methods are supported by the FOXWELL TS5000 TPMS Service Tool - Copy by Activation; Manual Create; Automatic Create.
    • Copy by OBD:
      • This method pulls the previously registered sensor ID through the vehicle's TPMS module using OBDII, and will then program the ID to the FOXWELL T10 sensor
      • This eliminates the need for a relearn by combining both steps into one
    • Copy by Activation
      • If your original sensor works and can be activated. You could use this method to program a new sensor. It will clone the original ID to the new FOXWELL T10 sensor.
    • Copy by Manual Input:
      • If you know the original sensor ID, you can input the ID to program new sensor.
    • Auto Create Sensors:
      • If you don't know the original sensor ID or your original sensor was bad, you can choose this method. Install new sensor ID--> program new sensor--> perform TPMS learning and let the car recognize new sensor
    Relearning -
    • OBD Relearn:
      • Usually the most effective relearn tactic, this will allow you to connect the TS5000 to your car wirelessly using the OBDII port and placing your vehicle in a relearn mode.
    • Automatic Relearn:
      • For some vehicles, the Relearn function can be completed automatically by driving, which makes it quite easy to do a complete set of sensor replacement operations on your own. Be aware that this may require you to drive the vehicle at a certain speed for a designated amount of time for it to relearn.
    • Stationary Relearn:
      • TS5000 allows the new TPMS sensor IDs to be transferred without driving a vehicle. You can trigger the sensors when the vehicle is in learn mode by our TPMS Tool TS5000. This will usually require a specific sequence created by the vehicle manufacturer as well, such as pressing the brake a few times, turning the key, etc.
    Please note that some vehicles require a combination of these relearning methods, such as needing to drive for a designated amount of time after relearning using OBD. There may also be extra steps your manufacturer uses, so please research your specific vehicle when performing a relearn!
    Note -
    • Certain functions may be limited from the vehicle manufacturer due to the requirement of a special factory access code.
      • Pre OBDII vehicles will have limited feature availability
    • We recommend purchasing a Bentley Manual to use with your TPMS Tool.
    • You will need to register your TPMS tool in order to receive update notice's from Foxwell via E-mail
    • Vehicles with 20 pin under hood connector will require ES2992111 for use
    $764.00
    WAS 1394.99 on 09/16/2025
    SALE:
    $1018.34
    (27% OFF)
    May Qualify for
    Free Shipping!
    - 440i Coupe (2017-18)
    The Foxwell i80II OBD2 Diagnostic Scan Tool is your ultimate companion for swift and accurate vehicle diagnostics. Designed for both DIY enthusiasts and professional mechanics, this scanner delivers comprehensive data to help identify and resolve engine issues with precision. Its user-friendly interface and robust build make it a must-have tool in any garage.
    Key Features -
    • Wide Compatibility: Supports all OBD2-compliant vehicles (1996 and newer), including cars, SUVs, and light trucks.
    • Advanced Diagnostics: Reads and clears diagnostic trouble codes (DTCs) for the engine, helping identify check engine light causes.
    • Live Data Stream: Displays real-time vehicle sensor data, enabling in-depth monitoring of your car's performance.
    • I/M Readiness Check: Prepare your vehicle for emissions testing by checking system readiness status.
    • Freeze Frame Data: Captures a snapshot of critical information at the time a trouble code is triggered.
    • Durable and Portable: Compact design with a sturdy, rugged build to withstand daily use.
    • Color Display and Intuitive Navigation: Features a bright LCD screen for easy viewing and a simple button layout for efficient operation.
    • Plug-and-Play Functionality: No need for batteries or charging - powers directly from your vehicle's OBD2 port.
    With the Foxwell i80II, you can take control of your vehicle's health and confidently tackle engine diagnostics. Whether you're clearing a pesky check engine light or diving into advanced data, this scan tool ensures you're equipped to keep your car running smoothly.
    Make diagnostics simple - add the Schwaben by Foxwell i80II OBD2 Diagnostic Scan Tool to your toolkit today!
    Support -
    In order to check specific vehicle coverage and functionality, visit https://www.foxwelltech.us/support-fun-list.html - Enter you device (this device can be found under i80II on Foxwell's site), your vehicle, and what code you are querying
    For software and hardware support from Foxwell the address is http://www.foxwelltech.com/support/ - Make sure you use the correct address
    For further support, contact [email protected]
    For further information past this, please contact Foxwell sales team at: [email protected]
    For technical support, please contact: https://www.foxwelltech.com/support/ticket
    WAS 679.99 on 09/16/2025
    SALE:
    $564.39
    (17% OFF)
    May Qualify for
    Free Shipping!
    The Foxwell TS7000 Tablet Diagnostic and TPMS Service Tool serves as your second or third step into TPMS diagnostics. It is a professional-level TPMS tool that not only offers TPMS features (the ability to activate OEM/Universal TPMS sensors, retrieve TPMS sensor data (sensor ID, tire pressure, temperature, battery condition and OE part number), relearn 98% sensor IDs, program FOXWELL T10-sensor to replace bad sensors and test Remote Keyless Entry Key Fobs), but ALSO offers many features of high-level diagnostic tools (ABS Bleeding, EVAP, Oil Resets, Fuel Pressure Testing, Oxygen Sensor Testing, and of course, Code Reading). With regular hardware and software updates, this tool empowers both technical professionals and automotive enthusiasts to tackle automotive issues with heightened precision and efficiency. It's the ideal choice for enthusiasts seeking next-level TPMS diagnostic capabilities without the typically steep costs associated with TPMS tools.
    Standout Features (How does it standout from cheaper models, i.e. the T1000/T2000?) -
    • **NEW WITH THIS MODEL, NOT ON THE TS5000**:
      • Supports many diagnostic functions of almost all vehicle systems
      • See "Diagnostic Features" in this description for more details
    • Larger screen (7-inch screen, TS5000 is 5.5-inch and T2000 is 2.8-inch)
    • CAN FD support
    More Features -
    • Code Reading capabilities
    • Protective Blow Molding Box: Prevent your scanner from damage
    • Free Software Updates for 4 Years
    Programming -
    With this TPMS programming tool, you can program FOXWELL T10 TPMS sensors (ES4335588 or ES4335589) to meet the specifications of a particular vehicle before new sensor installation and relearn. 4 different sensor programming methods are supported by the FOXWELL TS7000 TPMS Service Tool: Copy by Activation; Manual Create; Automatic Create. (Note - TS7000 will only program a replacement sensor if it is a FOXWELL T10 sensor, which can be easily found on our site.)
    • Copy by OBD:
    Diagnostic Features -
    • OE-level diagnostics for 130+ Makes
    • Supports models up to 2023
    • Run bi-directional tests
    • Supports 30+ commonly used service functions, including the following services:
      • ABS Bleeding
      • AFR Adaption
      • BRT
      • TPS
      • Clutch Adaption
      • CVT
      • DPF
      • EPB
      • EVAP/SMOG Test
      • Gearlearn
      • HeadLamp
      • Windowsdoor
      • Injector
      • Language Change
      • Odometer
      • Oil Reset
      • Prime Fuel Pump
      • Replace Airbag ECU Module
      • SAS
      • Seat Match
      • Turbo
      • TCMOIL
      • Transmission Adaptation
      • TPMS
      • Change Tire Size
      • Suspension
      • Immobilizer
      • EGR Reset
      • Fuel Pressure Test
      • G Sensor Learn
      • Oxygen Sensor Test
      • LIMIT
      • Power Balance
      • Ods Initialization
      • OPDS Initializaiton
    NOTE -
    • This scan tool covers over 25 years of models, so some years and or models, on some functions may not function but will be reviewed in future updates.
    WAS 209.99 on 09/16/2025
    SALE:
    $157.49
    (25% OFF)
    May Qualify for
    Free Shipping!
    The Foxwell T2000WF is a professional TPMS diagnostic and maintenance tool that can activate and decode universal TPMS sensors, program TPMS, and diagnose any OEM tire pressure monitoring system. Featuring updated hardware for quicker operation and all-new software for increased capability, the T2000WF provides a complete, full-service solution for owners of TPMS equipped vehicles.
    Features -
    • Sensor Activation and Decoding: The T2000WF can activate and read data from universal TPMS sensors, ensuring they function correctly.
    • Sensor Programming: Allows for programming TPMS sensors to replace faulty ones or install new sensors when needed.
    • System Diagnostics: This tool diagnoses the vehicle's TPMS to identify and troubleshoot issues within the system.
    • WiFi Connectivity: The 'WF' in T2000WF indicates WiFi capabilities, enabling wireless updates and seamless data transfer.
    • User-Friendly Interface: Designed with an intuitive interface to facilitate ease of use for technicians and automotive enthusiasts.
    This tool suits automotive professionals and enthusiasts seeking a reliable solution for TPMS-related services. If you're in need of a comprehensive, full-service diagnostic tool for your Tire Pressure Monitoring System equipped vehicle, look no further than the Foxwell T2000WF.
    Protects the ICOM during use and storage. Includes mounting hardware for tray and ICOM.
    BMW ICOM NEXT D Diagnostic Adapter for BMW Motorcycles. It connects to a ICOM NEXT A diagnostic head.
