Adding To Your Cart...
aFe Power Pro 5R Air Filters - Basic Maintenance for BMW E53 X5 4.8is (2004-2006) 4.8L
Constructed with 100% polyurethane on all four sides, this high-flow, oiled OE replacement performance filter will outflow the stock filter for improved horsepower and torque. The PRO 5R air filter uses five layers of progressively finer mesh cotton gauze media to provide maximum airflow for best performance results. Washable and reusable for multiple cleaning cycles, the tall, open, evenly spaced pleats provide excellent dust holding capacity for a longer service cycle between cleanings. An integrated urethane bump seal insures tight, no leak seal over the life of the filter.
$88.00
May Qualify for Free Shipping!
- X5 4.8is Sport Utility (2004-06)
Pro 5R Media -
This filter features a 5-layer progressive, oiled media to provide maximum flow with excellent filtration. The progressive layering of media allows the filter to flow at high levels even when dirty. The Pro 5R filter media is 98.6% efficient.
Rounded Open Pleats -
aFe performance air filters use a rounded pleat design which produces more useable filter surface area for more flow and greater dust holding capacity.
Progressive Bump Seal -
This pliable seeling surface conforms to even the most uneven filter housing. This design eliminates the use of gaskets or sealants. The soft urethane construction always goes back to its original form so you will never compress the bump seal. This makes for a perfect filter fit and sealing surface everytime.
aFe performance air filters are constructed using full 360 degree urethane frames. This construction allows for a proper OE style fit with excellent filter strength.
BMW 1/3-Series 04-09 L4-2.0L (EURO).
Constructed with 100% polyurethane on top and bottom, this high flow, oiled OE replacement performance filter will outflow stock paper filter for improved horsepower and torque. Five layers of progressively finer mesh cotton gauze media provide maxim...(click for more)
