Adding To Your Cart...
Timing Chain Tensioners - Engine for Porsche 911 (993) Carrera S (1998) 3.6L
The tolerances between the valves and pistons on some engines are very narrow, and this potentially disastrous dance between parts is all kept in harmony by the timing chain and tensioners. Make sure yours are all in proper working shape so you can continue to hear sweet sounds from your engine for years to come.
$16.00
May Qualify for Free Shipping!
- 993 Carrera S Coupe (1998)
$26.75
$14.75
OEM
$183.50
Also use (Qty.) (1) 964 105 177 03 gasket.
$408.30
$51.65
Also use (Qty.) (1) 999 701 909 40, (1) 999 707 288 40 o-rings, for each bridge.
$324.00
Stomski Racing's new compact versions of this tool allows for easier installation and removal, included thumbscrews can be used to attach these tensioners, no tools necessary. Precise springs and tolerances provide for proper tension of the chain...(click for more)
$149.00
2 required, Sold Individually, Replaces 99310708800.
The OE Porsche oil bridge is susceptible to leaking due to its plastic construction. The LN Engineering oil bridge, machined from 6061 aluminum, is a direct replacement for part number's 99310708800 and 96410708803. All-aluminum construction ensures ...(click for more)
$271.50
$408.30
Fluid for the Urea tank. For fluid filler funnel, use part number 7220.
$267.50
$281.00
