** USE 17-11-7-561-757-M202 INSTEAD ** Cooling Fan Assembly with Shroud, located between radiator and engine
Part #: 17-11-7-561-757-M14
(14)
View Product Details  |  Related Products
No Longer Available (NLA)
Quantity:
To determine if this part will fit your vehicle, please Click to verify your year, make & model
  • Bosch is an OEM supplier to European car manufacturers.
Notes: Located between radiator and engine.
Quantity in Stock:
Pelican Sales Rank:  25632
Time to Ship:
Weight:  1 lbs.
Warranty Info:  24 Months
Restrictions:
Confused about brands? Read our FAQ page.
This part is not associated with any kits.
Model:   323Ci (2000) Convertible with M52 Engine (E46)
Category:   Fan shroud
Description:   Fan housing with fan
   Quantity Required:   1
Notes:   390W
Model:   323Ci (2000) Coupe with M52 Engine (E46)
Notes:   390W
Model:   323i (1999-00) Sedan with M52 Engine (E46)
Notes:   (from 1998)
390W
Model:   323i (2000) Sedan with M52 Engine (E46)
Notes:   (from 1998)
390W
Model:   325Ci (2001-03) Convertible with M54 Engine (E46)
Notes:   390W
Model:   325Ci (2003-06) Convertible with M54 Engine (E46)
Notes:   390W
Model:   325Ci (2003-06) Coupe with M54 Engine (E46)
Notes:   390W
Model:   325Ci (2001-03) Coupe with M54 Engine (E46)
Notes:   390W
Model:   325i (2001) Sedan with M54 Engine (E46)
Notes:   390W
Notes:   390W
Model:   325i (2001-05) Sedan with M54 Engine (E46)
Notes:   390W
Model:   325i (2001) Wagon with M54 Engine (E46)
Notes:   390W
Model:   325i (2001-05) Wagon with M54 Engine (E46)
Notes:   390W
Model:   325xi (2001) Sedan with M54 Engine (E46)
Notes:   390W
Model:   325xi (2002-04) Sedan with M54 Engine (E46)
Notes:   390W
Model:   325xi (2001) Wagon with M54 Engine (E46)
Notes:   390W
Model:   325xi (2002-05) Wagon with M54 Engine (E46)
Notes:   390W
Model:   328Ci (2000) Coupe with M52 Engine (E46)
Notes:   390W
Model:   328i (1999-00) Sedan with M52 Engine (E46)
Notes:   (from 1998)
390W
Model:   330Ci (2001-03) Convertible with M54 Engine (E46)
Notes:   390W
Model:   330Ci (2003-06) Convertible with M54 Engine (E46)
Notes:   390W
Model:   330Ci (2003-06) Coupe with M54 Engine (E46)
Notes:   390W
Model:   330Ci (2001-03) Coupe with M54 Engine (E46)
Notes:   390W
Model:   330i (2001) Sedan with M54 Engine (E46)
Notes:   390W
Model:   330i (2002-05) Sedan with M54 Engine (E46)
Notes:   390W
Model:   330xi (2001) Sedan with M54 Engine (E46)
Notes:   390W
Model:   330xi (2002-05) Sedan with M54 Engine (E46)
Notes:   390W
Parts Diagrams:
BMW 3-Series (1999-2006)  [E46]
Click to View All Applications
This part fits the following vehicles:
(Quantity: 1 Required)
323i (1999-00, from 1998) Sedan with M52 Engine (E46)
323i (2000) Sedan with M52 Engine (E46) from 1998
328i (1999-00, from 1998) Sedan with M52 Engine (E46)
  Submit your Review of Part # 17-11-7-561-757-M14
Review title:
Overall rating:
How long have you owned this product?
Comments:
(Please give a detailed description of what you liked or disliked about this product)
(2,500 characters max)
Your name / nickname:
Upload a Photo:
* I have read and agree to abide by the Product Review Guidelines.
What our customers are saying:
Kyle B.
July 5, 2013
Fan installation.
Excellent quality from Bosch. swapped out/Installed in 10 minutes with no trouble at all.
Steve L.
May 29, 2013
Very easy install
Purchased this for my 2002 325Ci (manual) because the fan was stuck "on" even when car was turned off. Problem solved and still working great after a few thousand miles. You'll only need a torx driver to remove one screw. The unit slides up easily. I would strongly recommend purchasing extra rivets as my cracked when removing it (had to pick one up at the dealer for $1.50). Pretty sure the part number is 17-11-1-712-963-M58. Also make sure the shroud slides into the slots properly at the bottom. Installation took about 10-15 minutes, start to finish.
Todd S.
September 4, 2012
Easy Install/Working Perfectly
Good price, quality part, and fast shipping. Bought to replace fan on 2003 330i that was stuck in the ON position. With manual transmission install took literally 15 minutes.
Greg S.
July 31, 2012
Works great
Good quality, works. My car's A/C works fine again and no more check engine light or fears of overheating.
Fit was absolutely perfect!
Gregory G.
July 3, 2012
Worked perfectly on my 2000 323ci
I had the issue where the cooling fan began to run full speed and refused to cut off. I ordered this fan with overnight shipping from Pelican Parts and replaced my existing fan within 15 minutes of opening the shipping box. It was a perfect fit and the quality of the replacement part was as good or better than the original.
Brandon S.
June 28, 2012
OEM part at great cost
This is a Bosch OEM MADE IN GERMANY fan, for the same price others will sell you Chinese made OE replacements. This matches the fan that came out, except for the silver BMW sticker that doubles the cost
James H.
April 23, 2012
Excellent
Good price, very fast shipping, great product and insanely well packaged. Enough said.
Mark V.
August 24, 2011
Works great
Works great, dropped right into my 323i. It fixed my intermittent overheating and my AC problems. Quality seems on par or better than stock.
Mike K.
May 31, 2011
A great drop and plug in!!
I installed this in place of my stock viscous clutch fan. One screw, one plug, and one clip. Literally drops right in and cools great! Much easier to do maint now!
William C.
November 10, 2010
William
Thank You for The Good Service and The Prices. Very Good Upgrade for You Car..............
William C.
October 30, 2010
Excelent Service
Works Great Good Price Thank You Pelican Parts Always Great Service The Best Site for BMW Parts William..................
Roland B.
September 30, 2010
Perfect
Very pleased with this transaction, I made 2 phone calls to you and service was grate, just one thing, it will be nice to have a print friendly page to be able to print the receipt
Luke S.
May 12, 2010
Solved my overheating problem
This part apparently replaces/updates the BMW fan in my 99 323i 5/spd. It's half the price of the original part and has worked as it should for the past 2 weeks I've had it installed. It certainly remedied my overheating problem!
Sam T.
July 11, 2009
FIXED FAN PROBLEM
FAN WAS INSANE> NEVER SPINNING< THEN NEVER STOPPING>
Instant fix
Submit A Review
16 Please wait while we find related articles...
Ask us a question about this part! Email this page to yourself or a friend
QUICK LINKS
About Us
Careers
Pelican Parts, LLC
1600 240th Street
Harbor City, CA 90710
Order Online or Call:
888-280-7799
CONNECT WITH US
NEWSLETTER
Sign Up for Pelican Pit Stop News & Special Offers
CACHED: 1/20/2018 at 12:14:51
